Hi all!
New here and just hoping to get some here!
We are using a BT Business hub Router and it is having a few issues with wireless connectivity, so I would like to use another router to see if it is our equipment or if it is the router itself.
I have a Cisco Linksys E1000 Router and after looking at the BT router I can see that the connection type is set to PPPOA with a username and password. I do know the username and password so that isnt an issue, however on the Cisco router there is no option for PPPOA, the only options are:
Static IP, DHCP, PPPoE, PPTP, L2TP, and BigPond
There is a connection in the back of the cisco router for the ADSL cable, I was just wondering if there is a way to work around this?
Thanks very much!!
