Creating a website
greengirl
Member
I'm not hugely experienced at this and seem to be having quite a number of problems.
Really can't find who I should ask, just seem to go around in circles.
Some are not complicated but are complicated to explain if that makes sense!
One problem is that on my chosen template at the bottom of some type boxes there are little arrows for links. How do I change or set up a link. I also seem to be having big problems with the pages. I have created new pages to match the menu and every time I close and then reopen the next day other pages seem to have appeared in the manage pages section. All my problems are probably simple but it is so frustrating. The tutorial is useless!
Help please!
Greengirl
1 ACCEPTED SOLUTION
Accepted Solutions
Chantale
Master User
Hi
I have looked into the Easy Site Wizard Pro and seen that your pages are linking to the same pages. That is why you can't always see the changes. If you go in the Menu Editor then Options on a certain page, you can see they are linking to the same pages.
View solution in original post
5 REPLIES 5
orchie
Grand Master
Hey Greengirl,
Can you post the link to your website and let us know which package you are using e.g. hosting or eShop?
greengirl
Member
Hi,
The website isn't up yet but its just web hosting not an eshop. I have worked through alot of the problems but just can't sort out the page thing. I create a new page, do all the page property stuff and everything seems fine and then when I start working on the page it will either be a different page or it will be saved twice with a different .html name so its like I'm editing another page. Driving me mad. I did a page this morning, all seemed OK, saved it, then opened up this afternoon and when I go to the page I get my contact page instead. Don't know what I'm doing wrong.
Chantale
Master User
HI Green girl
Could you provide me with the domain name?
Thanks!!
greengirl
Member
Hi,
The domain is www.domairconditioning.com
Thanks.
Chantale
Master User
Hi
