- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi There,
I've created website in asp.net 3.5 and database in SQL Server 2005. I've got Advanced hosting service. Can somebody tell me if BT supports both of the above technologies so my website can work?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes to ASP.net 3.5 and No to SQL server 2005.
The only form of SQL suppoorted is MySQL
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for your reply. Can you suggest any solution?
Regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Can you believe a company like BT does not offer MS SQL server. MYSQL is cheap and sometimes not
user friendly. The easy integration that Microsoft builds into its development tools makes building powerfull web sites easy and a joy to use. Then you come across BT web hosting. If you consider the mess of BTs own web sites, the poor and unhelpful customer support anyone considering using BT web hosting should be advised to look elsewhere.
There are plenty of good professional web hosting providers so shop around.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To BT - OK you don't offer SQL Server (although you do not say why not if you're able to offer .Net 3.5 as the two go more or less hand in hand). However, I do know you can access MySQL databases from .Net, but you do need the MySQL ODBC driver installed on the server, so... is this driver installed?
It does restrict the complexity of the SQL strings you can use and, of course, you cannot use stored procedures, but at least it works.
If this driver isn't installed, why not? - in its absence you're effectively saying that .Net programmers are being denied access to any database, which, as you know, is the backbone and essential element of any web application.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi StuartHX,
Most of this is down to the properties of the packages that we offer, however in regards to the query about ODBC driver, you would need to have advanced hosting and we need to have this configured on the account before it can be used.
Normally this is done via a contact to the tech support desk. They would be able to arrange this for you.
Thanks in advance
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Have you guys eve thought of integrating barcode with ASP.NET project or SQL Server? Recently, I read an article that barcode can be generated in SSRS? Is it posssible?
