- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
I am trying to create a site for gosmotors.co.uk using the Easy Site Wizard - I have the basic layout he wants except for the image effects and wondered if I can add a flash image slideshow into it. I have already created a sample one in Flash so just need to add it to the website. It will be part of the header on the master page if that is possible. I tried to search the forum but could only find something to do with e-shop and couldn't find the same options in ESW.
I'd also considered doing this in Javascript but want to avoid some people being unable to see it properly if they have Javascript disabled.
thanks
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
That might be a little more advanced than Easy Site Wizard can handle. I would try adding it with the edit html source (on the top right of the editor) and verify that it works in the preview. I've never tried it myself but if the code is sound I can't see any reason why it would work. The only issue I can see going into it is viewing it in the editor, I don't think it would be able to read flash.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the info, I thought that would be the case. I'm only a basic programmer but will keep trying and if it doesn't work, I might try re-creating it outside the wizard. Thanks
