Easy site Wizard
rev3richie
Member
Hi, New here so go easy..
I've been putting together a quick web site using easy wizard, i have nearly finished but as its only a quick 1 pager, i have found i dont require the menu box system. i can delete it to 1 line, home, but how do i get rid of it completely.
Cheers
Rich
1 ACCEPTED SOLUTION
Accepted Solutions
duskjome
BT Partner
BT Partner
Unfortunately there is no way to do that with the current version of the program. It is something the programmers have been working on however so it will probably be in future versions.
Hope this helps.
View solution in original post
1 REPLY 1
duskjome
BT Partner
BT Partner
Hope this helps.
