- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Can anyone explain how I can use Easy Site Builder to create a hyperlink whereby when someone clicks on the email address it opens up a mail message which can then be sent. I have tried hyperlinking but this doesn't seem to work
Many Thanks
Andrew
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It would be the same procedure you use to create a regular hyperlink except that when you go to put in the URL you would put mailto:emailaddress and replace "emailaddress" with the actual email you want them the link to email.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
I still have problems. This is what I have tried:-
1. Click on hyperlink to another page or site
2. URL: remove http:// and replace with mailto:abc@123.com
3. Click on apply
Error: Please enter correct email address
It doesn't matter what email address I use, it still doesn't work
Please help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I trried the same on my site and it looks like you are correct. It seems like this feature is disabled in the current version of the Easy Site Wizard program. You can however create a mailto link in the source code with the "edit HTML source" under the "advanced options" icon on the top around the centre.
Hope this helps
