- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi There,
Both Starter and Advanced packages contain both the original EasyBlogBuilder (EBB) and the newer, EBB v2.0. .
I believe you are accessing the original, not v2. When you first run the application, you can specify if you want to have the blog at the main domain level or a sub-directory. Once its been selected and the blog is launched, it cannot be changed in the future. It’s a one-time set-up choice. In EBB v2 there is no such choice as to where to place the blog as in the original EBB - this was one of the key changes in the newer version.
I've tested the EBB with the option of setting up at the main level, and it overwrote my website (something which you probably do not want to happen!). Unfortunately there is no way to change this, so it is recommended that you set up a new blog on EBB V.2
There is no delete function or button to remove the blog directly from the application. We tested some methods using FTP and going through the website files to locate those associated with the blog and removing select files. If you go into your /private/blogger/ folder and remove the files and directories here, then also go to /public/blog2/template/images/ folder and remove the files here as well then the blog should be removed.
Hope this helps.
Thanks,
Lisa
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
2 years on from the first post, I have the same problem. A attempt to use EasyBlogBuilder has created some unusable but publicly visible pages. I too cannot find a way of deleting them, either by the tool itself or by File Manager.
Can anyone please help?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Changing the URL is possible:
Get Started
Layout Manager
Manage
Blog Profile.
Still don't know how to delete the blog altogether.
Any suggestions?
Nigel.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi There,
Hope this helps.
Thanks,
Lisa
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you. The blog has now gone.
Nigel.
