Editing a website that is already live?
lm32
Member
Ok so i am a total beginner at this web building lark, but have used vista web builder before for a forum i run and now am setting up a site for my dads small business. i have managed to configure the emails and got the site up and running but i need to edit a few things and add some pictures. however when i go into the wizard pro to edit it doesn;t bring up the website thats live only gives me an option to create a new site? i just want to edit the fax number on the site and add a few p[ics to personalise the site.
what am i doing wrong?
thanks
1 ACCEPTED SOLUTION
Accepted Solutions
spank
Grand Guru
Hi there,
I had this problem, seems to be some sort of security issue.  Try logging in again and if you see this message 'Do you want to view the webpage content that was delivered securely?' click NO.  If you click YES it fails.
View solution in original post
3 REPLIES 3
spank
Grand Guru
Hi there,
lm32
Member
Thanks for that, all sorted now.
JaffaParr
Member
Appreciate this message is old that I am using. I have a website that has been fine for years, i have managed to update on a regular basis but now cannot edit. I dont get a message about "secure delivery", I can go onto edit the site but cannot make changes. desperately need to update site.
