Web forms help!
PTWA
Member
Hi, I may be being really dim.... how do I edit the text in webforms? I need to be able to change the width/colour/font of the text I have input/inputed (sp?) as it's really small, and squashed up at the mo.
Does this make sense?
Mnay thanks
1 ACCEPTED SOLUTION
Accepted Solutions
duskjome
BT Partner
BT Partner
Looks like you might be right, I don't see the Easy Site Wizard tool letting you change the font size/color/etc. You could probably use the html editor, should be a little pencil on the top bar of Easy Site Wizard, and edit it manually there, just do a ctrl-f for the text you want to change and see if there is a font size option nearby... might work, should work
View solution in original post
9 REPLIES 9
Greatsports
Member
I think there must be a problem with it as the same thing is happening to my forms. I've got check boxes and they look fine on the page but when you look at the preview it misses off the first couple of characters. Will have to contact BT I guess.
PTWA
Member
Well, I managed to change the width of the form so the text isn't all scrunched up, but I really need to wokr out how to change the font size and clour ans it just looks really scrappy at the mo
Krystal
Member
Can I see your form online ? do you have a url.
Is it built using xhtml or a BT forum builder ?
PTWA
Member
Krystal
Member
Which page has the form on it ?
Greatsports
Member
Can someone please check out mine too if they have a sec? Its www.greatsports.org.uk and its the enquiry form. When I'm editing the form it looks fine but when I publish it its missing bits. Not sure if its just my computer???
pmillman
Power User
Hi,
I checked out your form online.  I really like that background.  I can see some minor formatting issues, but what seems to be missing?
Greatsports
Member
Thanks for checking. I managed to adjust the width of it last night which seems to have helped, at least none of the text is missing now. Not sure what else I can do with it really as can't edit font colour or size etc. I guess the form works though so that's all that matters.
duskjome
BT Partner
BT Partner
