Editing site created with Publisher (and uploaded via FTP) with EasySiteWizard
JDave
Member
Hi.  I have created my website in Microsoft Publisher (version 2007) and uploaded it via FTP.  All very easy, and the site displays as it should.  However, I would now like to edit the site using EasySiteWizard to take advantage of some of the features such as a form, but my site does not appear in the existing sites available to edit.
Can anyone offer any advice?  Thanks in advance.
1 ACCEPTED SOLUTION
Accepted Solutions
duskjome
BT Partner
BT Partner
Easy Site Wizard can only be used to create new sites, unfortunately it cannot edit sites built in other programs like Microsoft Publisher. However if you want to use it to build a form, or for any other features, you can create a new site in Easy site wizard and choose to publish it to a folder. This way you can retain your current site and link to the form or whatever other features you wanted to look into in Easy Site Wizard. Hope this helps.
View solution in original post
2 REPLIES 2
duskjome
BT Partner
BT Partner
JDave
Member
It does, thanks duskjome.
