Internet Business Pack Query
Matty
Member
Does anyone know if the Internet Business Pack automatically acceps CGI formmail?
I've used the wizard, but the formmail doc in the cgi-bin folder appears to be empty (when I try to download it, it comes up with "no such file or directory".
Any suggestions would be greatly appreciated (in novice speak if poss please).
3 REPLIES 3
duskjome
BT Partner
BT Partner
There should not be any issues with formmail if the cgi-bin folder was present when you installed it. If you are having problems downloading it it may be a permission problem. Try to rename the file in your file manager (double click cgi-bin under source directory, click the formmail file, enter a new name in the filename field and click "rename" on the left) If this works add a .txt to the end of the filename and choose edit to verify that it has text in the file.
Matty
Member
Thanks for that.
The Formmail doc in the cgi-bin folder definately has no text in it. It's also got the wrong date on it (i.e. if it was created today, shouldn't it have today's date on the file?)
Any ideas anyone?
duskjome
BT Partner
BT Partner
Did the file allow you to open it at all? If you were unable to open it it may be corrupt, in that case delete the file and reinstall the plugin. If it does open, but is blank, you will probably be fine to reset permissions (which you can do by checking all the boxes in the file manager after selecting the file and hitting reset perm on the left). Try both solutions though, just in case.
