Eshop Image resizing
TriggerWhitaker
Member
Hi,
I am unsure s to where I am going wrong, I have upload my products using a .csv file, to get the images to upload also, the only way I could see to do it was add a photobucket link to the pictures, this worked out great for three of the 4 product view pictures.  But I can not for the life of me see how to resize the list view image.
This is a link to the problem I am talking about.
The first car I uploaded manually from my computer.
The second saying image removed was me messing with the link to try and get it smaller
then the rest are how it comes when I upload.
http://www.comicsandcollectibles.co.uk/epages/Store3_Shop2387.sf/en_GB/?ObjectPath=/Shops/Store3.Shop2387/Categories/All_the_way_from_the_States/Disney_Pixar_Cars
I have a feeling I am uploading wrong, and I am supposed to use the gallery to do this, but I have looked everywhere for the gallery and I can't see it.
Please tell me there is an easy fix for this, as I have lots of products I want to get up and it will take a long time if I have to upload each product from my computer.
Thanks in Advance
Julie
1 REPLY 1
eShopTeam
Master User
Hello,
Better you should upload all your imagines in a masive way in your computer.
Once that you have done it you can upload all in once but you will have to assign it manually anyway.
For upload
->Design->advanced design->Insert file.
In the new window, file manager, click on "upload" and there you can select all of them.
You can even create differents folder in the file manager so it would be easy to find later the imagine for the assignation.
 In a future version 6.07 it would be possible to do massibe upload of product and category imagines.
For the moment we do not a date for the migration to this version.
Kind Regards,
The eShop Team
