Explain single and multiple static IPs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
i cant believe what ive just been told by BT.
BT
If you have a single static IP, you can use it as an external address.
If you have multple static IPs they must all be internal
Is it just me or is that crazy and wrong?
After probably 10 years of using one of the 8 static IPs as an external ip address, im now told all multiple static IP address are for internal use only (ie assigning to a PC)
BT are blaming my issues (after they upgraded me to ADSL2+ from ADSL2) on this, and saying that i will have to get a single static IP account instead.
Hello? am i going crazy?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Simonbratt99,
I'm sorry to read you are experiencing issues with your Static IP's.
I am not sure if I have picked up your enquiry right, but I am sure other people on the board will correct me if I'm wrong. Are you looking to have your IP's as NO NAT but at present they are set as NAT on the router?
The dynamic IP address assigned with No NAT acts as a carrier address for connection to the Internet. Once connected, the static addresses ensure permanent addresses for the computers they are assigned to on the Internet.
The Technical Team should be able to help you further with this.
I hope this helps
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Fiona,
We have a block of public static IPs ending in 0-7 from BT
0 is reserved for BT network
1-5 is for our use
6 is for the router
7 probably reserved also
We have been using these IPs fine for 4 years, and before that, a similar setup in another office for 10 years.
We use 1 to 5 for Firewalls, hosting webmail
when i do a whatismyip.com from my PC it comes up with IP 1 of the static list, which is our firewall.
Bt swap us from ADSL2 to ADSL2+ and then things dont work so well.
BT faults insist these IP addresses are for internal use only, and based on that they will not look at out uploading problem. And if we want an external IP we should be using a single static IP, not a range of static IPs. I find that unbelievable as an answer.
The problem being high ping speeds (measured from the routers Tracerouter) and dropouts if i upload a file, causing very slow internet access if a file is uploaded. Which is wrong and a fault somewhere.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi
Sorry for the delay in getting back to you . I have looked over the open technical case and can see that you are working with the technical team to get this resolved. You are due to get another call back on Tuesday, please let us know how you get on with this.
Kind Regards
Fiona
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
To the OP: What router do you use ?
It is very easy to accomplish what you want to do with a cisco 857/877 or the likes.
You simply unnumber the layer 2 ports (As the vlan, as the 857/877 have layer 2 ports) against the dialer interface, and assign the IP you were given as the hub address to this interface.
You then use this device as your default gateway on your network. I would recommend using a firewall behind this to handle all your NATs. I would generally use checkpoint FW-1 or Fortigate as we resell both.
I have used this setup successfully for about 5 years, and it still works even on the infinity service.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
We use Draytec Vigor 2800, but im also doing test with the BT Business router (new)
and whenever i upload something these are typical tracert results, direct from the router, no LAN attached
Its very bad, and BT so far dont know an answer. I am doing some more tests this weekend using a test account.
BT havent been very good at fixing my problem as this has been on going since July 2010.
www.google.co.uk
traceroute to 173.194.37.104, 30 hops max
1 81.139.128.1 1250 ms
2 213.120.178.141 1210 ms
3 213.120.177.98 1210 ms
4 213.120.176.30 1220 ms
5 213.120.176.178 1230 ms
6 109.159.249.70 1220 ms
7 109.159.249.25 1220 ms
8 62.172.102.17 1230 ms
9 195.99.126.26 1220 ms
10 209.85.255.175 1220 ms
11 209.85.251.202 1200 ms
12 173.194.37.104 1230 ms
Trace complete.
www.bt.com
traceroute to 62.239.237.2, 30 hops max
1 81.139.128.1 1240 ms
2 213.120.178.141 1230 ms
3 213.120.177.98 1240 ms
5 213.120.176.178 1220 ms
6 109.159.249.103 1250 ms
7 109.159.249.21 1230 ms
8 62.6.204.61 1230 ms
9 62.6.196.98 1270 ms
10 62.172.57.218 1250 ms
11 Request timed out. *
12 Request timed out. *
Trace complete.
Who thinks this is acceptable? no? didnt think so.
