Just got the BTPC fax set up, but when I send just a blank page is received at the receivers end fax
Any help please
Sheila
Solved! Go to Solution.
Hi Steph.
Thank you for sending me the link for FAQ I did try that and nothiong seemed to cover my problem, I then e-mailed BTPC for help, they seem to have sorted it their end, not really sure what the problem was but seems to be working now, they id say if the problem happens again, then get back to them, the persons dealing with my problem was very helpful, told me he had to pass it onto IT to deal with, which he did and all seems ok now.
Thank you again
Sheila
Hi Sheila,
here are a couple of FAQs and some troubleshooting info about the BT PC Fax service that may point you in the right direction, let us know how you get on.
Cheers,
Steph
Hi Steph.
Thank you again
Sheila
That's great to hear Sheila,
I am really glad the support guys were able to get the problem sorted!
Do get back to the forum if there is anything else you need help with.
Steph
