Fax Line on BT Hub 5
clive23
Member
Hi,
Not sure if this is the right forum but I will try.
Have Broadband on Hub 5. Have BT Telephone with 3 Panasonic Phones connected to Base Box installed by BT.
We have a Dell Printer with the possible use of Fax with the printer having a socket for a phone line.
The Fax element would only be used on a casual need. Only if necessary say possible 10 times in a year.
How can you connect to Base Unit the Fax Line?
Clive
1 REPLY 1
flashsnaps
Member
Yes you will need to plug the fax machine into the bt socket which you broadband is connected to.
You might need as microfilter depending on service.
