Solved! Go to Solution.
To change the color and font size you would have to edit the HTML code as this is not an option given in easysite wizard
How did you change the font size and colour? I just can't seem to work it out and no-one has answered my post
you can got to http://www.w3schools.com/html/html_colors.asp to see the colors codes this site should help with some of you questions, i have used this site a lot
