Hi, can anyone confirm if BT install a dedicated analogue line as part of a FttC installation (like they do with sDSL) or does the order actually get placed on an pre-installed line?
Solved! Go to Solution.
It will be installed on your existing analogue line - unless you specifically order an additional line which will have a phone number and montyhly rental charge.
SDSL uses the who frequency band right down into where the voice woiuld normally be whereas VDSL starts above the voice frequencies (plus a guard band) and extends up to 17MHz currently and could go as high as 30MHz.
Thanks for the quick response MHC.
Glad you have your questions answered. Analogue lines are still useful nowadays to provide a means of back up.
Good luck.
