Getting a Text Attribute to appear
norman
Member
Hi,
I have my website up and running.  I am looking to add some text fields to my website so that when my customers order a certain product (Dog or cat tag) they can add text that they want to appear on the tags.  This text is then sent with the order.  I can get a drop-down box appearing to select the correct tag but none of the text fields appear on the website.
I have setup a product type with 4 attributes, 1 drop-down box (which appears on website) and 3 text attributes.  All 4 are set to visible but as stated earlier the 3 text attributes don't appear.  Can anyone help me with this?
Paul.
1 REPLY 1
pmillman
Power User
Hi there,
That sounds like it  may be a coding issue.  If you would like to post your URL I'm sure we can figure it out.
Peter
