HTTP 403 Forbidden error for new domain name
simonb
Member
Can anyone possibly help me with this please?
I have a new BT domain name and am using their free 50MB space for my website.  I ordered it last Thursday and started using it this morning.  I have uploaded my site.
I can successfully view it from: home.btconnect.com/epsom-downs-windows.co.uk
However, if I type in just the domain name:  epsom-downs-windows.co.uk or www.epsom-downs-windows.co.uk all I get is HTTP 403 Forbidden "The website declined to show this webpage"
My index.html is definitely all in lower case and I copied it to index.htm just in case it made a difference (it did not)
Because I am not paying for hosting, BT don't offer free assistance, so I would be very grateful for any advice.
Many thanks, Debbie
1 ACCEPTED SOLUTION
Accepted Solutions
cowan85
Member
You should be able to re-point this yourself by logging in to myoffice.bt.com using your primary email/password. Click "manage services" then in the "Domains" section click on "manage your domain names". In here you should be able you forward to your free webspace. URL forwarding will do a simple re-direct, with visitors able to see the "home.btconnect.com" part wheras frame re-direct will hide this but might affect Google rankings.
View solution in original post
4 REPLIES 4
gs
Super User
You need to get in touch with BT and getthem to point your domain name towards the free space, currently it doesnt. www.dnsforms.co.uk might be able to do it for you. It might not be them that help you if you are a pay as you go customer, but they can provide you the number for assistance. There is a number, I have spoken to them before.
gs
cowan85
Member
orchie
Grand Master
Hi Simon,
I've just checked and your site works fine, this is most likely your DNS settings on your computer. Try rebooting your internet router and computer, clearing out your temporary internet files and doing a DNS flush and it should be fine.
simonb
Member
many thanks to you all for your help.
cowan85 -  I immediately did what you said, and I'm sure this was a necessary part of the initial setup, but more was needed...
gs - you were absolutely correct.  BT had to sort this one out.  They "made an update to the original setup records" and said it was not something I could do online.  They would not explain to me what they had done, but all worked a treat about 5 mins after they had done it.
