Hi Im new on here, can anyone help with this please
According to google webmaster tools I have 17 http 403 errors and 1 WebRoot 404 not found thingy!!! I have no clue as you can probably tell, what this means or how to fix it.....Please help
It is also telling me to combine css files and the number of dns look ups. Any help would be much appreciated
thanks
Hi Noonoo
Error 403 indicates that the request is forbidden. You don't have access to enter the website.
A 403 error message on your website means that the web server is pointing to a folder but cannot find the appropriate file or homepage. The web server does not know what to do and returns this error.
The server looks in the folder for the first page to display when the domain name is entered and, if the page exists, then shows the site.
A common reason for this error to occur is that a directory index has been requested in a directory for which such requests have been specifically disallowed. If this is the reason, you need to change the filename of your homepage, change the default homepage setting or undo the disallow setting.
If you still need further help you can contact the helpdesk on 0845 600 7020 and follow the options for broadband
Frances
Forum Moderator
_____________________________________________
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully
Hi Frances
thanks for your help on the 403 errors I think i have that bit sorted.
with regards to the 404 error on my website ( I dont think i mentioned in my last post my website is a bteshop) this is what googles crawl errors is showing - not sure what to do about this
| 404 (Not found) | 100 pages | Aug 14, 2010 |
Hi
There is information on our help and support files as to what an Error 404 means. Basically it is where a file has been moved, renamed or siliar. From the error that google tools it giving it looks like it says that http://www.weddinginvitationsandfavours.co.uk/WebRoot is not a valid link or being found, The page you selected has either been deleted or renamed.
I hope this helps
Kind Regards
Fiona
BT Business Forum Moderator
