Help !! Cant upload new website !
sandeno
Member
ive created a new web site to replace my existing one (created with magix web designer5). New site created using
web plus x6 and ive tried every permutation u could think of for the ftp settings and i keep getting the error message
"An error has occured whilst trying to get the working directory from the ftp server".
Entry fields are
FTP Address   ftphost.btconnect.com
port no :21
folder public
username castle-landscapes
password
passive mode- checked
Home page is named index.
Dont know what else to do aaaghhhhhh
4 REPLIES 4
markp
Grand Guru
Hi sandeno,
If you are trying to upload your website to a paid for hosting pack these are the settings you need:
FTP Address   ftp.yourdomain.co.uk
port no :21
folder public
username yourdomain.co.uk
I hope this helps.
Regards
Markp
sandeno
Member
Thanks for the reply but that doesnt work im getting the error message "an error occured whist trying to get the working directory from the FTP server".
Any other replies would be greatly appreciated
Burkem5
Guru
Hi Sandeno
What happens when you try to get access via windows rather than FTP client?
Steps are as follows
Right click on the start button
Click Explore
In the folder you should see an address bar, in this type ftp.yourdomain.com (ex, ftp.sandeno.com)
When you press enter you will get an error,  this is normal.
Click OK on the error box then right click on any clear space in that window.
Then click "Login as..."
then fire in your full FTP details
Username - your domain (ex, sandeno.com)
Let me know if this helps
Burkem5
sandeno
Member
thanks for the reply but when trying this the error message "windows cannot access this folder make sure you have typed correctly and you have permission-the connection with server was reset"
