I have had my mail set up for a long time on my mobile and for the last week not a single email as downloaded or sent. I manually tell it to load more messages and nothing - and there are new messages in my inbox every day so I know I have them on the server.
I have logged in to Office 365 and checked the setitngs, the POP3 and SMTP were slightly wrong (they used to work with the settings I had, so don't know why they have now changed) but anyway, I have changed to the settings it tells me and still no emails downloading.
I am using -
POP3 - outlook.office365.com
Port - 995
Security Type - SSL
SMTP - smtp.office365.com
Port - 587
Security Type - TLS
Require sign in is ticked and username and password are both entered correctly.
What on earth am I doing wrong??? The last email I had was on 17/8/13, what's happened since then?
Please help asap as I need to know when I have new emails.
Hi Magfo
can you try these settings and tell me how you get on ?
Incoming server
Server - pop.outlook.com
port – 995
connection type – ssl
ensure that this is authorised with the full email address and password including the domain [email protected]
Outgoing
Server - smtp.outlook.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
hope this helps
