- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
<form method="POST" action="/cgi-bin/formmail">
<input type="hidden" name="recipient" value="auto_reply@mydomain.com">
<input type="hidden" name="env_report" value="REMOTE_HOST,REMOTE_ADDR,HTTP_USER_AGENT"> [need to get this info from form]
<input TYPE="hidden" NAME="return_link_url" VALUE="http://www.mydomain.com">
<!--- do not change this line --->
<input type="hidden" name="print_config" value="realname,email,subject">
<!--- input all your own fields in sort the order your want them --->
<input type="hidden" name="sort" value="order:lastname">
<input type="hidden" name="required" value="firstname,lastname,email,telephone,subject,message">
<input type="hidden" name="print_blank_fields" value="1">
Your First Name *
<br>
<input type="text" size="35" maxlength="30" name="firstname" value="">
<br>
<br>
Your Last Name *
<br>
<input type="text" size="35" maxlength="30" name="lastname" value="">
<br>
<br>
Your Email *
<br>
<input type="text" size="35" name="email" value="">
<br>
<br>
Your Telephone Number *
<br>
<input type="text" size="35" maxlength="30" name="telephone" value="">
<br>
<br>
Subject *
<br>
<input type="text" size="35" maxlength="30" name="subject" value="Help">
<br>
<br>
Message *
<br>
<textarea name="message" rows="10" cols="35">Dear Fleming Consulting </textarea>
<br>
<br>
<input type="submit" value="Send message">
<input type="reset" value="Clear Form"></form>
<!-- HTML Markup endspan --></div>
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
See the configuration instructions at http://www.scriptarchive.com/readme/formmail.html#form_config
Both of these features as well as others are explained by the script author in this document.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try adding a hidden field specifying a value for realname (email display name). Without this, the incoming mail server will likely drop the email as spam.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Dave,
The form is now showing me the submittal screen (have not received test mails yet but that is something I can cope with). Any ideas how I get the 'env_report' working and also how I put up a 'redirect' to a custom "thank you page'.
Would be extremely grateful for your knowledge in this area.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
