Help Setting Up Connection on Netgear DG834G (5 Static IPs)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
My BT router has just broken, so I'm trying to use a Netgear DG834g temporarily until I receive a new one. I have 5 static IPs, but I'm struggling to get any internet connection when I try to enter the static IP address manually. If I allow the router to dynamically get the IP, I connect but my IP address is not in my static range. Any suggestions?
Thanks,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
someone has done a write up here
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks Rich. Do you know which setting the Multiplexing Method should be set to as it still doesn't work?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
for bt it should be vc-mux
vpi should be 0 and vci should be 38
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I still get disconnected everytime I try to set it to a fixed IP....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
just do what it says in the guide, don't try and set the router to a static ip address
bt use peered static ip addresses, so they are routed to the dhcp assigned ip address thats linked with your login details
you need to make sure you are using the proper login details, username@hg****** blah blah
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
When I follow those instructions, my router does not have a static IP address - it changes each time I reboot it, meaning my VPN loses connection.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
do you need 5 static ip addresses? if not, ask bt to change to a single, then you will get a static ip address for the router.
as another step, you could setup dyndns for the router, then connect vpn to dyndns address.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It's not really possible to set up a VPN to the router itself, with multiple static IPs. In which case, you should set up the VPN to the specific devices which have static IP addresses assigned to them. Alternatively, the Single static IP "fix" is going to be necessary.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
yeah, my vpn is handled by my sbs2011 server
if you setup dyndns on the router you can vpn to the router
