Home Voip over Business Hub (2700HGV) - calls dropped after 8 mins. Help!
BSH
Member
I have just converted from Home Broadband (BTHomeHub) to Business Broadband, because I needed a static IP for business. I want to keep my Home VOIP Tel number as I have been using it for business and changing it is a pain.
BT said I could use the 2700HGV to accomplish this, and set the configuration up for me, BUT the line gets cut off after approx 8 minutes (always the same amount of time as per the log on the Router - 481 seconds). BT have not been very helpful in resolving this.
Any ideas, or should I just take out a BT Business VOIP line?
1 REPLY 1
SeanC
Master User
Hi BSH
Res is not 100% compatible with business equipment but it will work, not always.
Can you tell me what how the helpdesk setup the res voip on the 2700?
