How do I get a verified externally hosted domain removed from my account?
Craig_Paterson
Member
I recently verified an externally hosted domain on my account, but no longer want to use it. I want to revert back to using [email protected].
How do I go about getting the verified domain removed. It seems easy enough to add, it. But cannot for the life of me find a way to have it removed.
Any help or pointers much appreciated.
4 REPLIES 4
markp
Grand Guru
Hi Craig,
If you contact the helpdesk they will be able to get it removed for you
Regards
Markp
BT Business Forum Moderator
Craig_Paterson
Member
Thanks Mark,
I am actually a web developer and this is for a cutomers account. Will I be able to converse with support on their behalf. The client is not particularly versed with IT related issues.
C
markp
Grand Guru
Hi Craig,
as long as you can verify the account and pass security, you can deal with the helpdesk on your clients behalf.
Regards
Markp
Craig_Paterson
Member
Thanks Mark,
Managed to speak to support last night and waiting on a response back today hopefully.
Craig
