I have this account for over 18 months and cannoy access "Easy Website Pro". Why? How do you do access this as I need to alter a page and I just cannot find it........help!
Solved! Go to Solution.
Hi pete511,
If you go to http://myofice.bt.com and click on manage services. This will give you a username and password box,
login as your main @btconnect.com email address and password.
Once logged in you will see a section for web hosting, in this section click on Manage Web hosting and Online Stores,
on the new page select manage <yourdomainname.co.uk>.
This wil take you to the website centre where you will be able to access Easy site wizard pro.
Regards
Markp
BT Business Forum Moderator
You have to contact BT to assist you with it. I am not sure if there are certain fee to be added for this.
Hi pete511,
Regards
Markp
Thanks Markp, worked like a charm!
