How do access Easy website pro?
pete511
Member
I have this account for over 18 months and cannoy access "Easy Website Pro". Why? How do you do access this as I need to alter a page and I just cannot find it........help!
1 ACCEPTED SOLUTION
Accepted Solutions
markp
Grand Guru
Hi pete511,
If you go to http://myofice.bt.com and click on manage services.  This will give you a username and password box,
login as your main @btconnect.com email address and password.
Once logged in you will see a section for web hosting, in this section click on Manage Web hosting and Online Stores,
on the new page select manage <yourdomainname.co.uk>.
This wil take you to the website centre where you will be able to access Easy site wizard pro.
Regards
Markp
BT Business Forum Moderator
View solution in original post
3 REPLIES 3
mydearcosmo
Power User
You have to contact BT to assist you with it. I am not sure if there are certain fee to be added for this.
markp
Grand Guru
Hi pete511,
Regards
Markp
pete511
Member
Thanks Markp, worked like a charm!
