As above does anyone know how to change the shape and colour of the box/border around images of products on the homepage or even not have a box/border?
Solved! Go to Solution.
Hello,
*Content/Categories->Datasheet view->Layout->Products
Here you can change the boxes to one column, two columns, three columns, large boxes or small boxes.
Also you can upload your own box
*Design->Advanced design
On the view, click on the central area.
Now you choose from the preview drop down menu, "Prices and products view".
In the block "Products view" you should choose from the drop down menu "Product box on the Home page"
You can "delete template" and upload your owns.
Kind Regards,
Hi 18ME,
I've looked at your website and I think it may be the "categories" or "subpages" list that you meant that you have on your homepage. These can be changed by following the same process as detailed by the eShopTeam only selecting "Lists, Tables & Dialogues" instead of "Products & Prices" and changing the row colours.
Thanks for your help.
I've been messing about with the settings which is why the catagories are now showing on the homepage, which I quite like at the minute, not sure how others see it though. When I first asked the question there were no catagories in the middle only on the left side as usual and a few products in the middle where the Scanglobe is now under the middle catagories.
The reason why I first asked is that I've seen some epages websites that don't have a box/border at all around the products on the homepage but I'm thinking this maybe due to the different templates.
Hello,
Doing:
"delete template"
You will delete the box. If you have choose a layout in columms then you will still having a line for separating the products, but if you choose a layout in large or small boxes then you wont see this line.
Also you can try to delete the home page background image (it may look different the around of the boxes), If you dont like how it looks you can restore the template without problem.
