Hi, this may sound like a ridiculous question, but I would like a slideshow on my opening page, and noticed that there is a 'coverlflow' option. I have selected it, but no pics come up, how do I get pictures onto it for my opening page? Gareth Lynch is the link. Any help would be much appreciated.
Please contact the BT technical support team,they will assist you in their best way ![]()
Hello costy
I've just checked your website and you still don't have the cover flow. Either you didn't contact BT support, or they couldn't help (probably the latter).
It's fairly straightforward to set up. Go to Content/Categories > Layout. Make sure you select an option for Products in the Sort Order section. Then scroll to bottom of page and select Cover Flow under Products.
Now go to Content/Categories > Products. Make sure you have some products assigned to the homepage.
That should do it.
