- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi.
After a line issue now resolved, I now require an IP profile reset.
System Up Time 143:26:15
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 703745 972504 0 284 4344 53:52:31
LAN 10M/100M 1368679 1066773 0 2209 215 143:26:10
WLAN 11M/54M 193290 192446 0 383 30 143:24:47
ADSL Link Downstream Upstream
Connection Speed 284 kbps 1104 kbps
Line Attenuation 18 db 4.5 db
Noise Margin 31 db 6 db
As you can see the downstream sync is 284kbps. Noise margin 31db. Based on line capability the downstream sync should be around 15Mbps.
I have run the BT wholesale speedtest and the following results for downstream:
Speed achieved: 0.25Mbps
IP Profile: 0.25Mbps
Please can one of the mods respond so I can get this issue resolved.
Regards.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi nickaminsky
If you contact the helpdesk, they will be able to look at the line, and depending on the line type get a reset put through for you. If it is a fibre line they will need to organise an engineer to come out to reset the profile.
Markp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi nickaminsky
Markp
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks all sorted. Spoke to helpdesk over chat who confirmed the profile was stuck and now reset getting 15Mbps.
