ISDN2e - No Connection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi folks I'm trying at setting up phone systems at work and can't get it working. What I have: ISDN2e from BT. Seimens Gigaset DX800A all-in-one phone system (1 x base, 6 x handsets) What I have done: I connect 1 cable (RJ14 perhaps) from BT NTE8 ISDN2e box to base station. Base station recognises ISDN line and starts connection wizard. I get a solid green light on ISDN2e box. Base station doesn't recognise MSN number - I manually set this and end wizard. However, when I try and dial, I get no connection. I've tried various combinations for the MSN number: 44131 XXX XXXX 0131 XXX XXXX 131 XXX XXXX XXX XXXX XX XXXX No success. BT has tested the line and reports no faults. Any help/ideas would be appreciated! Thanks Dave |
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
On most telephone systems when programming MSNs you don't need the area code. In your area which is a Director area I don't know if you would need the exchange code as well so just try the last 4 digits.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Davel
Thanks for the suggestion - I've tried this, but still no luck. Any more ideas?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Normally if you don't programme a MSN it willl automatically ring the main handset or group. What do you get if you ring the number?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Every time I get call failed!
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I agree as I don't usually use area codes. Whenever I dial a number, it will automatically recognize where I am calling.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Dave,
Did you ever get a resolve for this issue we have the DX800a, BT isdn 2e and get the same issue.
Hugh
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
hi davel........
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi,
did you manage to get your system working in the end? If so what did you need to do?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Once we knew this, it was simple for bt to do.
Dave
