If vdsl is going to be used due to copper to the house does the adsl socket need to be replaced
beaver
Member
Can vdsl run through the normal adsl socket in the house? We will not have fibre coming to the house so will we need the BT adsl socket replaced for vdsl?
2 REPLIES 2
MHC
Guru
The filter will need to be replaced.   The old ADSL filters will work but are not of high enough quality at the top end.  The VDSL filter has been fully tested and charactersied up to 20MHz or so, well above the top limit for current VDSL
mithcd
Power User
Hi op, were you able to proceed with the VDSL?
