Infinity - How to see my usage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
I am on BT Business infinity/fibre
Is there a way that I can see my internet usage?
I have 100gb a month and need to check if im getting close to it
What happenes if I go over it?
Thanks for help in advance
Stuart
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Currently, there is no usage monitor, stumoore. you will be alerted via e-mail when you approach your usage limit. This is usually sent to your @btconnect.com address.
Current excess usage charges are 10-12GB - £6, 13 - 15GB - £12 and in excess of 20GB - £37.50. These charges will, of course, exclude VAT.
100GB/month is really quite a high level, on the ADSL side of things, we rarely see usages that high. However, for £5/month extra, you could change to unlimited usage. My recommendation is, if you require higher usage than 100GB, it makes sense to upgrade.
BT Infinity for Business
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There is no perfect way, but if you know all of te PCs that connect via your network, the consider installing tbbmeter on each PC.
http://www.thinkbroadband.com/tbbmeter.html
Each PC keeps a record whioch is uploaded daily and the TOTAL for all PCs connected is available online. If your month does not run 1st to 31st then you may need to do some quick addition/subtraction, but it will give a good indication and when you are getting lose.
