Internet Explorer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi,
Im having problems with internet Explorer, I have tried updating via microsoft and changing security options, also tried running IE7 and compatibility mode, however my browser will not display images or web sites as they should be.
I have google chrome and it works perfectly however some BT applications are not compatible, (my web space), can you help,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
charlie17 wrote: browser will not display images or web sites as they should be.
What is wrong on what page? http://????
and stop faffing about with IE7, use the latest version as your default web browser.
If it is a web page that you have made using a BT application then the problem is not your web browser, it's a common HTML coding problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks, im now using IE9, however,
On google homepage the "Google" does not display,
On BT, none of the colours on the page appear on my browser, and none of the options buttons appear (next)
Google chrome works perfectly, however as I last wrote, it isnt compatible with all sites.
I cant make my web page using BT's site as none of the options or icons are available. (just text).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Sounds like you have managed to managed to disable Javascript or block images with the privacy controls for Interent Explorer. Could try going to -> Internet Options/ Security/ Custom Level and reset everything to Medium default and seeing if that helps
