Ip Address
Hsp
Member
If I have got an IP address - how do we know whether it is static ??
Thank you
1 ACCEPTED SOLUTION
Accepted Solutions
WaltJabsco
Member
Go to www.whatismyip.com
Take a note of your IP and then switch your router off for 3 mins.
Back on then go to www.whatismyip.com
If you get the same IP then you got yourself a static. If it's different then you have a dynamic IP
If you want a static then go to www.myoffice.bt.com , click on Manage Services. Log in. Click on Connection Settings then you will see the option to get a static. A single is a fiver per month.
View solution in original post
1 REPLY 1
WaltJabsco
Member
