Is Joomla supported by BT
tviljoen
Member
Could anyone please confirm whether or not Joomla is supported by BT? I have been advised to upgrade to the Advanced Hosting Package but BT helpdesk today told me that Joomla is not supported!!!!
2 REPLIES 2
duskjome
BT Partner
BT Partner
BT does not provide support for Joomla but from my experience Joomla works on almost any server that allows FTP and a MySql database. If you have these two things in your package you should be fine. Hope this helps.
dave
Guru
It would depend on how you define 'support'.
The servers should support it, i.e it should run on BT's servers.
BT will not provide technical support for it, meaning don't ask them for help if you are having problems setting it up or using it because you will not get it.
