Linking pages in EasySiteWizard
plewsey
Member
Hello,
I am setting up a site using EasySiteWizard but I am having a problem linking a photo to a new page that I have created. I can see the new page that I have created but I cant see where the address for the page is kept. I can see where I add the URL on the photo but all of my pages seem to have the same URL "https://hosting.hostingbt.com/OS4/index.php?frameLoader=sitemanager_FS#" Has anyone got any ideas where I can find the individual URL's?
Peter
1 ACCEPTED SOLUTION
Accepted Solutions
Tracey
Guru
Hi Plewsey,
You would need to put all the pages into your public folder, once you click the publish button after doing this your website should go live.
Tracey
BT Forum Moderator
If you like a post please click on the star image on the left-hand side of the post.
If someone answers your question correctly please let other Forum members know by clicking on Accept as Solution on the right-hand side of the answer post. Please also consider replying to the post stating that your question has been answered successfully.
View solution in original post
6 REPLIES 6
plewsey
Member
I did see an answer and have tried http://www.mywebaddress/page.1/html  but when I hit the check link option it still fails. Any ideas please?
Fiona
Grand Guru
Hi
I'm sorry about the problems. If you can let me know your domain name, the version of EasySiteWizard youare using (Pro or 6.0), and details of the page you have created and where you have created it, and i can try and get some information for you.
Kind Regards
Fiona
BT Business Forum Moderator
Like this post, or any others? Please click on the star image on the left hand side if you do.
If you ask a question by putting up the first post in a thread and a follow-up post answers your question correctly, please let other Forum members know which post contains the correct answer by clicking on the 'Accept as Solution' button on the right hand side of the post.
plewsey
Member
Hi Fiona,
I am using EasySiteWizard 6.0 and the details are www.tlmags.com  the page that I am trying to link to is http://www.tlmags.com/page.1html  and I am linking from The Travel & Leisure Magazine front cover photo on the page  http://www.tlmags.com/page.2html. It is strange as I can link to external sites and see them when I use the check link facility but not the internal pages.
Thanks for your help.
Regards
Peter
Fiona
Grand Guru
Hi
It looks like you don't have any other pages, except index.html, under your public folder.  This will be why you are unable to create links to the pages(http://www.tlmags.com/page1.html, http://www.tlmags.com/page2.html). In order to be able to create working links, you should have these pages under your public folder.
Kind Regards
Fiona
plewsey
Member
Hi Fiona,
Does this mean that when I have finished creating the site and press the publish button the pages will automatically go into my public folder or do I have to do something else to make them live?
Regards
Peter
Tracey
Guru
Hi Plewsey,
Tracey
BT Forum Moderator
