Does anyone please know how to put a link within a page - ie from a list at the top to a part of the page further down?
Babyabroad
Solved! Go to Solution.
Hey babyabroad,
What you need to is create "Anchors" on the page and then link to them from a menu. A lot of websites use this for "back to top" buttons for example.
1.The first thing to do is to create the anchor on your page by using this code with "go to bottom of the page" as an example where you want the menu item to take you, so lets say this anchor is right at the bottom of the page:
<a name="#bottomofpage"></a>
Note that between the >< you can enter any text.
2.Now on your menu/list you need to link to this so use the following on your menu:
<a href="#bottomofpage">Go to Bottom of Page</a>
And thats it, you are all done, here is a demo for you, if you have any more questions just post back.
Hey babyabroad,
Thanks Orchie for a really helpful response.
I'm putting the website together using the easysitewizard. Does that mean that I can't view the code? I also haven't yet published the site- does that cause a problem too?
Babyabroad
