MX record for Subdomain
wiggy42
Member
Hi,
We have a domain with BT. We wish to use a subdomain for a email elsewhere
So xyz.com is our main address
     email.xyz.com is to be used for email elsewhere
Is it possible to set up an MX record for a subdomain?
I have managed to set up the A record, but can't see how I would attribute the mx record to the subdomain and not the domain.
6 REPLIES 6
Ian1974
Moderator
Moderator
Hi Wiggy42,
This will need to be added as follows.
Type - MX
Key   - @
Value - email.xyz.com
Plus your A record as follows.
Type  -  A
Key    -  email
Value  -  IP address of the new server.
This should work, if not please let me know.
Kind Regards,
Ian - F -
BT Business Domains
wiggy42
Member
Thank you
Is it possible to set up spf records for this subdomain without affecting the main domain?
Ian1974
Moderator
Moderator
I can confirm this is possible.
It is just a case of entering the "key" as "email" as follows.
Type  -  TXT
Key    -  email
Value  -  Spf record.
Kind Regards,
Ian - F -
BT Business Domains
wiggy42
Member
Hi Ian,
Thanks for that.
I have now been instructed that for email.xyz.com I need to set up two equal priority records
MX 10 abc.com
MX 10 EFG.com
How would I handle this so it is attributed to email.xyz.com and not xyz.com
I am also having issues adding a DKIM record due to the character limit to the field in the interface, I suspect I will need to call BT to sort this one.
Ian1974
Moderator
Moderator
Hi Wiggy42,
Please can you sent me a private message with the exact instructions, as well as the DKIM record as these can only be added on our side.
Thanks,
Ian - F -
BT Business Domains
wiggy42
Member
Hi Ian,
I haev PM'd you
