Mac email won't send
GrandpaChris
Member
Suddenly I can't send emails using Mac Mail - they just sit in the Outbox. I checked my accounts and settings are identical to my iPhone (and worked fine yesterday). I followed the thread on this forum, putting in the IP addresses, renaming my Mac, deleting it from my network and rebooting, etc., all except Option 3 which involves a terminal window as I have no iea how to create one. My apologies but it won't let me reply to that thread.
1 ACCEPTED SOLUTION
Accepted Solutions
GrandpaChris
Member
Hi Mark
My apologies. I just searched for Mac mail not working and didn't spot it saying Business.
Chris
View solution in original post
4 REPLIES 4
Burkem5
Guru
Hi there @GrandpaChris
If this has started out of the blue then more than likely you have just updated the software,  i know we were seeing some issues where "Mavericks" updates have disabled some of the settings on Mac Mail.
Can you do me a favour and make sure that you are using the following settings
Incoming server
Server – outlook.office365.com
port – 995
connection type – ssl
ensure that this is authorised with the full email address and password including the domain [email protected]
Outgoing
Server - smtp.office365.com
port – 587
connection type – tls
make sure the outgoing server requires authentication and authenticate with the same details as the incoming server
Once we know that these are all ok then we can move to the more complex fixes.
Let me know how you get on with these.
Burkem5
GrandpaChris
Member
Hi
I updated to Mavericks a while ago and have not noticed any updates over the last few days. It won't let me change the incoming server (mail.btinternet.com) which is greyed out but I've made the other changes.
When I try to set up TLS, it offers one TLS certificate to use - com.apple.idms.appleid... so I picked that. I changed the outgoing server from mail.btinternet.com to smtp.office365.com. It just adds "(offline)" after the server name and does not make any difference.
By the way, the settings you gave me are very different from the ones I used to use which still work on my iPhone.
Chris
markp
Grand Guru
Hi GrandpaChris,
if you were using the servers mail.btinternet.com and smtp.btinternet.com, there are our home broadband email servers for @btinternet.com email address, the office365.com server names are for business @btconnect.com and domain name emails.
If you are having an issue with @btinternet.com you can contact our home broadband team on 0800 111 4567, www.bt.com/chat or buy going to their forum at https://community.bt.com/
Markp
GrandpaChris
Member
Hi Mark
Chris
