Good evening. Is assistance available regarding the matter below?
(1) When preparing the menu bar in EasySiteWizard Professional, the button width option sets all the buttons widths even when only one button is selected for editing. How can the width of an individual button be set?
(2) The menu bar has quite a few buttons, so that at first they are automatically put on two lines. When the button width is set so that all buttons fit on to one line, the total length of all the buttons is then too short to be the same as the page width. And then when saving, ESW Pro puts them onto two lines again.
Thank you for your assistance.
I'd recommend that you consult the User guide, you should be able to edit button width in EasySiteWizard:
EasySiteWizard Pro User Guide
Thank you however the Wizard changes all the buttons' widths regardless of which specific button is selected.
The button widths can be set within the CSS editor. The button number can be found in the HTML code by looking for the particular text which then has a specific button number. That button number's properties are then set in the CSS code.
There is still the problem of the menu appearing offset from the left handside of the page even though the CSS code has 0px as the setting for the left side. On the preview, the menu still appears offset.
