Hi everyone, firstly can i just say that I am totally new at websites so I'm afraid I know nothing about it. I've used easysite wizard to attempt to build a site - it still needs vast amounts of work - and i accidentally pressed the 'publish' button yesterday. Oh well go with it I thought, & tried to view it online. When i did, the Menu has moved all the way over to the right for some reason, but in the editor its still where I left it. Could anyone please help?
Also, I don't really know where to put the verification meta thingy for google, I found the HTML edit button and pasted it where I thought it might need to go, and the google thingy doesn't seem to be able to verify it, but as I really don't understand much about it, I thought the best thing to do would be to put myself in the hands of you guys who obviously understand loads!
Many thanks in advance
MHH
It sounds like the editor is not publishing the content in the editor correctly. You can check the content on the live site with "View source" in your browser and this will give you most of the code that the browser is viewing, including the meta tags. You should be able to see them in this window that comes up when you view source.
If it is not there try to republish the site, after making sure that the tags are still in the editor of course and this should work.
Hope this helps.
