We are shortly moving our office to a different area but would like to take two current numbers with us. They are going to be in a different area code (01787 to 01376). What would be the best way to do this? I'm looking at keeping this as cost effective as I can. It also needs to be done fairly quickly.
I was thinking of looking at a VoIP package so that once the numbers are on there, any further office moves in the future mean our numbers stay with us wherever we are. It would also mean that I can work from home and still have access to the phones rather than having to go in to the office.
Hi Desmo,
Our Business Movers Team should be able to assist with all aspects of this. Hope this helps.
I am thinking of moving my office to my home and I want to take my office number to my home address.
My office number is 020 8540 9995
I had a fax number at home but because I was not using , I got it disconnected.
So perhaps that line can be used to bring in 020 8540 9995.
Hello Bharat,
If your home number and office number are on the same exchange you could have a new line installed with your office number on it. If you Private Message (PM) me with your home number I can check this for you.
If not you have a couple of options:
1) You only need to receive calls on this number could have a simple Number Translation Service which will redirect office calls to your home number. You can also add various options such as call whisper so that you know it is a business call.
2) If you need to receive and make calls from this number and have broadband at home you could use Voice over Internet Protocol (VoIP). This is feature rich, flexible and cost effective.
If you would like to know more about either of these options PM me with your contact number and I will call you.
Kind regards,
Stuart
