The line is a "BT Business Total Broadband Option 2" with 1 static IP address which was installed back in 2008.
Originally, we were using Netopia modems, but the exchange has been recently updated, and these modems are no longer compatible, so we replaced them with the Netgear DG834 V4's which we have successfully deployed at many other locations around the UK.
The symptom is that after a random period of between 15 minutes and 6 days, the router appears to disconnect from the internet and requires a reboot/power cycle to get it back on.
Thinking it was a hardware fault, we replaced the router with another unit including the cables and micro-filter - no change.
The username/password are as per the original BT emails.
ADSL Settings are; VC-Based, VPI=0, VCI=38
DSL Mode: We have tried - Auto(multi-mode), ADSL2+, G.DMT all with same result.
Router Settings: PPPoA, Never logout, Get IP Dynamically, Get DNS from ISP, NAT enabled.
BT say there is no problem with the line or the exchange, and that its our router at fault. I find that hard to believe considering I have literally dozens of these working with exactly the same hardware/configuration settings at other locations!
Can anyone help? Thanks.
There should be logs on the netgear device that would give us clues on what's going on. Can you paste some? Specifically on the time that the connection was interrupted.
There is nothing unusual in the logs I can see; is there some logs which I can FTP off the device which contain more detail?
Mon, 2012-04-02 14:35:39 - Router start up
Thu, 2012-04-12 14:59:47 - Administrator login successful - IP:
Thu, 2012-04-12 15:04:36 - LCP down.
Thu, 2012-04-12 15:05:30 - Initialize LCP.
Thu, 2012-04-12 15:05:30 - LCP is allowed to come up.
Thu, 2012-04-12 15:05:31 - CHAP authentication success
Thu, 2012-04-12 15:07:17 - Administrator login successful - IP:
Thu, 2012-04-12 15:07:34 - Administrator login successful - IP:
Thu, 2012-04-12 15:14:18 - LCP down.
Thu, 2012-04-12 15:15:07 - Initialize LCP.
Thu, 2012-04-12 15:15:07 - LCP is allowed to come up.
Thu, 2012-04-12 15:15:10 - CHAP authentication success
(IP addresses edited out for obvious reasons)
BT came in yesterday and told us the line is less than 100m from the exchange, and other than the Noise margin being tweaked to 6db, there wasn't much else they could do.
Interestingly, even though the router seemed to think it was connected to the infernalnet, for some reason we couldn't reach any external sites (e.g. bbc.co.uk); forcing a disconnect and reconnect get it working again.
Lets see what it thinks in the morning!
| System Up Time 242:08:54 | ||||||||||||||||||||||||
This mornings stats; I note the Tx & Rx B/s has dropped significantly since yesterday afternoon, but I don't know how they measure that.
| System Up Time 258:30:55 | ||||||||||||||||||||||||
| Router Status | |
| Account Name | |
| Firmware Version | V5.01.16 |
| ADSL Port | |
| MAC Address | removed |
| IP Address | removed |
| Network Type | PPPoA |
| IP Subnet Mask | 255.255.255.255 |
| Gateway IP Address | removed |
| Domain Name Server | 194.72.9.38 62.6.40.162 |
| LAN Port | |
| IP Address | 172.16.59.254 |
| DHCP | On |
| IP Subnet Mask | 255.255.255.0 |
| Modem | |
| ADSL Firmware Version | A2pB023b.d20e |
| Modem Status | Connected |
| DownStream Connection Speed | 20463 kbps |
| UpStream Connection Speed | 888 kbps |
| VPI | 0 |
| VCI | 38 |
