Netgear Router and Static IP's
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hello Forum, first time user here.
We have a number of sites on BT ADSL on which we use Netgear DG834 wired routers. We find that they intermittently lock up every 1-2 weeks, no internet access is available even though the router lights stay green. Only a power cycle will get them to work. All sites are on different exchanges.
Each site has a static IP and 5 extra IP addresses. However, when visiting a site today I found the following:
The Netgear router states:
Router Status
Account Name
Firmware Version V5.01.16
ADSL Port
MAC Address 00:26:F2:50:xx:xx
IP Address 81.134.xxx.xxx
Network Type PPPoA
IP Subnet Mask 255.255.255.255
Gateway IP Address 81.134.xxx.xxx
Domain Name Server 194.74.xxx.xxx
194.72.xxx.xxx
LAN Port
MAC Address 00:26:F2:50:B0:42
IP Address 217.37.xxx.xxx
DHCP Off
IP Subnet Mask 255.255.255.248
Modem
ADSL Firmware Version A2pB023b.d20e
Modem Status Connected
DownStream Connection Speed 10629 kbps
UpStream Connection Speed 1200 kbps
VPI 0
VCI 38
Our IP address range from the welcome pack is:
You’ve ordered a range of Static IP addresses, which contains 8 addresses from 217.37.xxx.xxx to 217.37.xxx.xxx. Three of these are reserved: network address: 217.37.xxx.xxx router/Hub address: 217.37.xxx.xxx subnet mask address if you have 5 Static IP addresses: 255.255.255.248
As you can see from the ‘ADSL Port’ on the Netgear Router the IP address begins 81.134 which is not in our range, is this correct?
Is anyone else experiencing this intermittant locking up issue?
Many thanks
Keith
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you familiar with the 81.134 subnet? You might want to check if this is assgined through DHCP or not. Is the ADSL facing the LAN or WAN side? there might be another DHCP server somewhere if the IP was through DHCP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your routers WAN port will always obtain a dynamic IP, this is normal. To get proper routing over your static IP's you need to disable NAT on the WAN port. Even though the router has a dynamic IP, the machines assigned with an IP within your range will route properly over their own IP when NAT is disabled.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks a-hill, this is the case.
It does not explain our multi-site, once per two week lockouts that we are getting though. Any ideas?
Keith
