New ADSL connection. 8128 sync 2000 ip profile
LuaKT
Member
Hi,
BT business broadband was setup on Friday and I have been connected at 8128kbps over the weekend but my IP Profile is still showing 2000kbps. I understand that it can take a while to change but previously all IP Profile changes have happened within 2 days. I hear that it is more common to have a stuck profile at 2000kbps on a line that has never had broadband before, which mine hasn't. I am hestitant to contact BT because they will just say it's still within the 10 day training period and refuse to do anything. My online order tracking page still says "In Progress" due for Monday the 21st...
Any advice?
1 ACCEPTED SOLUTION
Accepted Solutions
MHC
Guru
Almost certainly a stuck profile ...  As it is "flatlining" at the same level, just below 2Mbps it suggest that it has not been updated since your move/upgrade.
Call support and talk them through what you have seen, what you have done and that ebven after several days there has been no change.     If you get teh right support agent they will understand and get teh profile reset.
View solution in original post
16 REPLIES 16
kimura
Super User
Hi. They'll probably gonna change but since it's weekend, they don't have work. You're getting an actual speed of ~~8Mbps which is a good thing. 🙂
MHC
Guru
Don't you get fed up with making pointless posts which do not even make sense and are often totally WRONG.   There are several here who are getting fed up with you.
To the OP.    Do not keep turning the modem/hub on and off, occasional is OK but frequent can make it worse.
Power teh hub off completely and leave it off for 30 minutes.     Then restart everything.    Run a full BT speedtest and post the report and also a copy of your router stats would be useful.
LuaKT
Member
I'm a bit worried to do this because it might seem like an unstable line and reset the tiime it takes for the profile to increase. Should I just go ahead and do it anyway?
MHC
Guru
Turning it off ONCE and leaving it for 30 minutes will not affect it.   But ten times in an hour might cause the DLM to lower the sync speed because of perceived instability.   It is also worth disconnecting the connection to the phone socket too.   Then when you reboot, power up, leave 2 minutes to stabilise and then connect back to teh phone socket.
Have a look at:  http://www.kitz.co.uk/adsl/IPprofile.htm and scroll down to teh table which show teh approximate times for an increase in Profile to occur.     2000 to just about 7600 is 380% so it could happen in a matter of hours.
So, after rebooting, leave it on for 5 hours then off for 30 minutes again and see if there is a change.    And repeat tomorrow morning.
LuaKT
Member
Okay just turned it back on after 30 minutes and it's resynced at 8128 still. IP Profile is still set to 2000. Will see how it goes, thanks
Here are the router stats now:
Mode:G.DMT
Type:Interleave
Line Coding:Trellis On
Status:No defect
 DownstreamUpstream
Rate (Kbps):8128 448
SNR Margin (dB):11.1 21.0
Attenuation (dB):9.0 3.5
Output Power (dBm):12.3 9.8
Super Frames:47848 47847
Super Frame Errors:
RS Words:6507392 811393
RS Correctable Errors:
RS Uncorrectable Errors:N/A
HEC Errors:
OCD Errors:
LCD Errors:
Total Cells:15574453
Data Cells:357313
Bit Errors:
Total ES:
Total SES:
Total UAS:41
MHC
Guru
Open Windows task manager (or whatever it is called in your version of windows) and select the Networking tab.
Run a speedtest, or try downloading a large file.
Take a screenshot of task manager, save it to your desktop and then attach teh image to a post here along with speedtest results.    That will show what ACTUAL throughput you are getting.
If it does not shift from 2000 by mid-day tomorrow, you could have a stuck profile and it will need resttting but you may not get any joy until the 10 training period is over.
LuaKT
Member
http://speedtest.net/result/1962202452.png to the nearest server
MHC
Guru
Can you repeat that a few times,  but get an image of the Task Manager screen.
LuaKT
Member
Heres me downloading the Think Broadband 1GB test file twice.
http://i.imgur.com/SbYof.png
http://i.imgur.com/fULBM.png
