How do I set up a new folder in my office email as I need one for storage?
Solved! Go to Solution.
Hi Alice
Just to check is this a new folder in the same mailbox?
Here are some step by steps to make a new folder.
1. Right-click the main (parent) folder that you want to create a folder off of.
2. Select "New Folder..." from the menu that appears.
3. Enter the name you want to call the folder (in the "Name:" text box).
4. From the "Folder contains:" drop-down menu, select what you want to put in the new folder.
Hope this helps,
Del
Hi Alice
Hope this helps,
Del
I use outlook express, I had a sub folder which was deleted. I'm trying to set it up again but it's failing to send a test email. I get a message to use the password my ISP has given me...? or that this address is already in use. HELP
