I have just had to have a replacement router from BT. Installed as instructed and everything working fine but I have lost the ability to use right click to forward, delete, move etc. Everything worked before the replacement - how do I get it back?
Using Internet Explorer 8 - Outlook Web Access for mail.
Solved! Go to Solution.
There is a known issue with IE8 and IE9 and the use of some of the components in OWA. Instead of using myoffice.bt.com as the URL, try using the URL of email.btconnect.com. This is resolving a lot of issues.
Hello Birdbrain
Did you get an answer to your question about losing your right click function on OWA. We have that problem here...Thanks Derek
Hello Birdbrain1
No - haven't had an answer yet!
Thank you so much - everything works as it should.
