I would like to change the outgoing caller id from my 056 number to the geographic number for my VOIP line. How can I do this?
Did you manage to resolve this? There was an excellent post by Sean from BT a while ago that helped me as I could not see how to do it either.... see below
Tom
26-05-2011 09:50 AM
Hi Arceng
You can not set the caller ID on the MADN line and the reason for this is the MADN is only a group and when you make an outbound call this is done via the actual phone you are using.
to set this on each handset this can be done in 2 ways 1st we can set this up for you or 2nd you can go towww.bt.com/businessbbv/selfcare login with your BBV details and click manage your lines then scroll down and click on the line you want to change and after you have clicked line on the new page scroll down until you come to the caller display option and select the number you require from the drop down menu, this will need to be done for all lines.
Hope this helps
Regards
Sean
I replicated the issue here at my end. The link really works.
